Would a sound card fit here?
Laucien
35
I'm planning to buy an "Asus ROG Xonar Phoebus" for my current setup but I'm not sure if it would fit along with my SLI GTX970 >.>.
My current motherboard is an ASUS Maximus VII Ranger and I'm using the 2 red PCIe ports for the GPUs. All the other expansion ports are empty.
Here's a link to the motherboard details/specs https://www.asus.com/Motherboards/MAXIMUS_VII_RANGER/ and here are two pics I just took showing the GPUs and the topmost pci-e x1 port http://imgur.com/a/cxMOl.
I'm wondering if the soundcard would fit in the top most PCIe x1 port (above the GPU) or if I can use the PCIe x4 at the bottom (bellow both GPUs and right above the PSU) to connect the soundcard.
