Would a Zalman ZM80C-HP hetpipe cooler fit my Radeon 9600 ..
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
And does anyone have one of these on my card or anyother how is it ?
My Silent PC project.
Thanks.
In news:0ft990dla3gjjlc5bi9bch9p3801qmvl45@4ax.com,
We Live For The One We Die For The One <Mr fred@yahoo.com.au> Quoth The
Raven:
> Thanks.
I am pretty sure it should, this cooler will fit most 9500-9800 series cards
as long as you have 2 holes on either side of the gpu. although having one
of these wont necessarily quieten your pc, as a fan is recommended to either
be on the sink or blowing at the sink from elsewhere to remove heat.
If all the world is a stage, where is the audience sitting?
Take out the CUSSIN to reply to me
I know i have 1 120mm fan at the bootom front 3 at the top 80mm
includeing PSU and one at the side :), all undervolted to 7 volts uing
a fan controler.
I just want to get the 40mm ect WHINNY fans out some they whole system
want a low HUMMMMMMMMMMMMMm, quieter yes but not silent i know.
Iam going to add OFF switches to all my fans as well so only the
needed fans will be on like when not playing games ect.
Going to get a Northbridge heatsink as well today Zalman NB47j its
BLUE :), one less WHINNY FAN :)
Lets see if it makes TOO much of a difference, getting a Silent Boost
as well.
That should make a Difference.
See ya.
On Sun, 2 May 2004 23:35:09 +1000, "Highlandish"
>Raven:
>> Thanks.
