would a Zotac GTX 970 Amp Omega fit in fractal design r4 case?
MattyTheMid
pc part-picker said it is unable to verify that there would be enough space in the case to fit the card, does anyone happen to know for sure if it will fit or not? thanks a lot.
Yes, the Zotac GTX 970 AMP! Omega graphics card will fit in the Fractal Design R4 case. It will support graphics cards up to 295mm with the top drive cages, and support up to 430mm graphics cards with the drive cages removed. The graphics card is 267.97 mm.
