Question Would all these parts work together?
Apr 14, 2019
I’m debating on buying a new pc, this is the link to all of it.
THE CASE :
NZXT H500i - Compact ATX Mid-Tower PC Gaming Case - RGB Lighting and Fan Control - CAM-Powered Smart Device - Tempered Glass Panel - Enhanced Cable Management System – Water-Cooling Ready - Black/Blue https://www.amazon.co.uk/dp/B07D7KP97M/ref=cm_sw_r_cp_api_i_Uu5SCbCNJ58FG
SSD :
Samsung MZ-76E1T0B/EU 1 TB 860 EVO Sata III 64L V NAND Solid State Drive https://www.amazon.co.uk/dp/B078WST5RK/ref=cm_sw_r_cp_api_i_nw5SCbSZPT66R
Motherboard:
ASUS ROG STRIX B450-F GAMING AM4/B450/DDR4/S-ATA 600/ATX Socket Motherboard - Black https://www.amazon.co.uk/dp/B07F714FT7/ref=cm_sw_r_cp_api_i_Hx5SCbZ43FEJR
CPU::
AMD Ryzen 5 2600X Processor with Wraith Spire Cooler - YD260XBCAFBOX https://www.amazon.co.uk/dp/B07B428V2L/ref=cm_sw_r_cp_api_i_Ty5SCbBT7ESBN
Power supply:
Corsair CP-9020099-UK CX850M 850 W 80 Plus Bronze Certified Modular ATX 135 mm Fan Power Supply Unit - Black https://www.amazon.co.uk/dp/B00P2GDQZ8/ref=cm_sw_r_cp_api_i_sz5SCb949C2JM
I also have a graphics card that’s going in (may be upgrading)
Asus Ceberus GTX1050 Ti Advanced Graphic Card (4GB DDR5, PCIe3, DVI, HDMI, DP, 1442MHz OC) https://www.amazon.co.uk/dp/B078ZT22SS/ref=cm_sw_r_cp_api_i_kA5SCbQGJHKN2
1x 16gb ram : ADATA XPG Z1 16 GB DDR4 2400 MHz CL16 Memory Modules - Red https://www.amazon.co.uk/dp/B01LXHJBE4/ref=cm_sw_r_cp_api_i_vB5SCbWERWZ5T
I also have a 8gb version of the same ram
R_1
Judicious
Herald
looks pretty good, a suggestion though after the caution.
Caution: Ryzen can be picky when it comes to RAM, the RAM you are providing the CPU is the slowest supported speed, AND you are mixing modules. mixing modules is always a gamble, the only RAM that is guaranteed to work together are sold as a kit, a matched set.
I would get 2 x 8 GB 3000Mhz cas 15 or 16 RAM for the Ryzen CPU. a matched set that is tested to work in dual channel. Ryzens sweetspot for memory is @2933mhz so memory that is made to go faster can run at that speed with no issue or problem.
I would sell the 8GB module and any other parts left over and use that for the GPU fund.
I saw no mention of a monitor. if the resolution is 1080p or less the GPU upgrade can hold a bit, if resolution is higher a GPU upgrade is suggested ASAP.
Apr 14, 2019
I mean, the ram works fine, it’s been tested in another build, and I had no problems with it, I mean but yes, I will be getting other monitors, 1080p for now, not sure if the whole build would fit in that pc or not? As in would I need other wires etc? I’m new to building pcs that’s why I’m here hah, thank you tho!
R_1
Judicious
Herald
the case, motherboard, and power supply will provide all the needed cables.
you can take cables from the old system, SATA being the main cable you may need and one may ship with the SSD.
everything should fit fine, that is a spacious case.
if you mix the RAM modules test them together thoroughly.
memtest86 is the preferred in depth test. let the program run for 5 passes, if after 5 complete passes you get no errors or reboots, congrats they will work. test may take better part of 2 days.
Apr 14, 2019
This may sound stupid, but would everything fit in the case? (NZXT one?) and the gpu I have, goes off mobo power, would that work? And do I need to buy a new HDD? To go with my SSD, I have one in my old build but I don’t know if there’s any point and would I need a new Windows 10
R_1
Judicious
Herald
fit? check
mobo power? check the 1050 is a 75W card and the PCIe slot provides 75W.
HDD? you can re-use the old hard drive, the SSD will provide speed (install windows with only the SSD installed - after updates shut down and connect the HDD for mass storage) so the old drive will be the mass storage slow data. only need new drive if you need more space. (with a 1TB ssd I would use the old drive depending on size of course)
NEW Windows? if windows came with the system you will need a new license (OEM is tied to the hardware). you can run the OS un-activated for extended periods and activate when you can afford to. not a necessity right this second.
as mdd1963 mentioned 850W is a bit much, however you mentioned wanting a new GPU later so 850W would be apropos with a 1070-2080 card. the PSU will be working at near half capacity then and will be working at maximun efficiency. cooler means less heat in the case. the PSU will only provide what the system requires it will not be consuming 850W all the time.
pcpartpicker could save a few quid, I could not find that exact module so the list has the 32GB shown but the price is from the amazonuk 16GB module you selected
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor (£169.50 @ Aria PC)
Motherboard: Asus - ROG STRIX B450-F GAMING ATX AM4 Motherboard (£116.88 @ Technextday)
Memory: ADATA - XPG Z1 32 GB (2 x 16 GB) DDR4-2400 Memory (£110.41)
Storage: Samsung - 860 Evo 1 TB 2.5" Solid State Drive (£134.51 @ Aria PC)
Video Card: Asus - GeForce GTX 1050 Ti 4 GB CERBERUS Video Card (Purchased For £0.00)
Case: NZXT - H500i (Black) ATX Mid Tower Case (£96.65 @ Amazon UK)
Power Supply: Corsair - 850 W 80+ Bronze Certified Semi-Modular ATX Power Supply (£79.99 @ AWD-IT)
Total: £707.94
Generated by PCPartPicker 2019-04-14 23:39 BST+0100
Reactions: Omen x
