Question Would anyone recommend using a random chinese power supply?
Jul 2, 2019
18
I know this probably sounds stupid. But I have a build that's only missing a power supply. I found a Delux DLP-550a in a custom built kiosk that I won in an auction a while. All the writing on it is in chinese. It appears to be 500w but I cant be sure.
Using it would save me $65 atleast and the system I plan on putting it in is relatively low spec and not too power intensive.
I've attached pictures of the power supply below, any thoughts?
Pictures:
https://ibb.co/XDNsKqF
DSzymborski
Glorious
Pictures:
Pictures:
Well, I'm sure that the component companies would recommend you use it so that they can sell you new components to replace the fried ones.
Reactions: jonnyguru
Jul 2, 2019
18
Lmfao. Well that's a conclusive answer.
Thanks for the quick responses!
I will go ahead and shell out the money for a new one.
