I'm really interested in starting streaming and have done lots of research on the topic already, trying out lots of methods too (Simply using OBS on my computer and also using a two computer setup with my macbook pro, using the NDI plugin for OBS) but haven't been too successful. Streaming with OBS alone on my computer is great, however what i output onto twitch is limited with the bitrate that i can put out (at the moment the max i can go is around 4000) which causes the stream to look slightly pixelated, and often lag heavily.
Im not sure if getting a capture card would fix any of this or not, but the particular motherboard i have (gigabyte b450m ds3h microatx) has no spare pcie, with the only one being underneath where the graphics card is sitting - unable for usage. As a result i would be limited to getting a USB 3.0 capture card and i have no idea whether this would be worth it.
Im looking to stream at 1080p 60fps, but honestly not sure where the problems lie, and if getting a capture card would even benefit the situation. Any help would be greatly appreciated!!!
