Would buying a EVGA gtx 1060 SC 6GB and over clocking it heat up my CPU?
Ryan_183
Commendable
Aug 24, 2016
106
Ok so i'm like so new to this pc build stuff and i was thinking about getting the EVGA gtx 1060 SC 6GB GPU (once it is in stock....good lord i hope i can get one before my 3 months are up) anyway what i need to know is does overclocking the GPU also heat up the CPU because truth be told i don't want to overclock my CPU do to wanting to use a stock fan But i would like to overclock the GPU i just don't want to heat up my CPU at the same time.
Not significantly, only if your case can't properly vent the extra heat created by the GPU OC, which would likely mean you'd have temperature problems before OCing.
