M Mrttooth Prominent May 5, 2017 6 0 510 May 5, 2017 #1 I have never made a forum before and dont know to much about computers and i wanted to know if the corsair vengeance 2400mhz worked with the z87 G41
Solution Dark Lord of Tech May 5, 2017 XMP PROFILE 1 in the BIOS under DRAM settings it will run them.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 5, 2017 #2 DDR3 1066/1333/1600/1866*/2000*/2133*/2200*/2400*/2600*/2666*/2800*/3000*(*OC) MHz If you setup XMP in the BIOS under DRAM settings it will run them. Upvote 0 Downvote
M Mrttooth Prominent May 5, 2017 6 0 510 May 5, 2017 #3 How would I do that on this motherboard Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 5, 2017 Solution #4 XMP PROFILE 1 in the BIOS under DRAM settings it will run them. Upvote 0 Downvote Solution
