Would installing a soundcard besides onboard Realtek audio management?
ColManischewitz
Hello, and thank you for any help you can provide.
I have Realtek onboard sound management. About 6 months ago, it started causing awful problems with my headset settings -- it would reset microphone audio, and not, it just pain won't work without causing a lot of feedback.
If I installed a separate sound card, could I just use that for all sound and bypass the RealTek onboard management? Would this work for headsets with traditional 3.5 microphone connects as well as USB headsets/microphones, which my Realtek won't recognize?
USB headsets have their own "soundcard" chip built in. They will use neither the Realtek chip nor any soundcard you install. If you have compatibility issues with a USB headset, you can disable the onboard sound (Realtek) in your bios.
A soundcard could help you with a 3.5mm headset, but what you are experiencing sounds like a driver/software error. You might be able to fix it by uninstalling your realtek management and/or reinstalling it.
Thank you!
