would intel hd graphics 4400 sufficient for running softwares like pro-e ,autocad2014,ansys,photshop
kamal kumar 299
please notify me the software's which are supported by the intel hd grapics 4400.Will this graphics support software's like pro-e ,ansys, autocad2014, adobe photoshop ???
Yes. I bought the Wacom Companion which has the HD 4000. I have installed and tested the full Autodesk Product Design Suite Ultimate, Adobe Production Premium CS6, and various other software. I have another computer that we installed PTC Creo 2 on.
Alias Design 2014= OK (some blacking out of boxes from time to time but perfectly usable)
Showcase 2014= OK (Sluggish but can work in a pinch)
Inventor Pro 2014=OK (Inventor messes with Windows 8 & 8.1-Recommend not install)
Sketchbook Pro/Designer 2014=Recommended
3DS Max 2014= OK
Maya 2014= OK
Mudbox 2014= NO. Needs discreet graphics
Z Brush= OK
Photoshop cs6= OK
Illustrator cs6= OK
After Affects cs6= I don't remember testing
Unity 4.3= OK
PTC Creo 2=OK
Ansys= ???
AutoCAD 2014= ???
I hope that this helps
Kevin.
