Question Would it be a problem if the LGA1151 DMI_RXN [2] pin is bent?
May 27, 2024
11
Hello, I have an MSI Z270 Gaming Pro Carbon motherboard and an i3 7100 processor. Unfortunately, there is a slight bend in the DMI_RXN [2] pin of my motherboard. What exactly does this DMI_RXN [2] do? Will it cause any issues with the proper functioning of the system?
When I say the pin is bent, it’s not a simple bend. Unfortunately, I cannot take a photo because my phone is broken, but to explain it simply:
It's not just a slight tilt or a shift to the side; the pin is actually bent, and it’s impossible for me to repair it at home.
The pin should look like this:
My pin looks like this:
Unless you can find exactly what that pin does, it may be anything possible.
No effect at all, or no boot at all.
Or multiple things in between.
