Would like opinions on a new but kind of odd build and some help picking a motherboard
kogo50
80
Hello,
I would like some opinions on a new build I'm doing. Like the title says I would like to do something a little odd if it is worth it/doable but I'm not sure if it is or not. This build is going to replace a Dell Precision T5500 I have with the dual Intel Xeon x5650s and 24GB of DDR3 ECC RAM. I like the machine but there are a few things that want to make me replace most of it.
Machine is used as my daily driver. Do development, test some stuff, and do all the usual things one would do on a computer. Run Arch Linux on it most of the time with Windows on another drive. Would like to fix that by running Windows as a VM and passing through the gx960 but thats an experiment for later.
I was going to get all new parts. That build is here. http://pcpartpicker.com/p/fTFXC
Want to do pretty much the same build LinusTechTips did in their "How to Build the ULTIMATE Silent Gaming or Workstation PC" guide here.(http://www.youtube.com/watch?v=RXZrWqCT7R0&list=PLA3E2CFDFDA2C3F99&index=2) Changed the PSU and going to use the be quiet! DARK ROCK 3 SilentWings CPU Cooler not the Pro. Two video cards.
I started to think about it and I would like to spend less if possible but also I would assume the dual x5650s would be better than the CPU in the parts list or at least be close in performance. So now I would like to get most of the parts on the list besides the motherboard, CPU, and RAM and get a decent LGA 1366 dual socket motherboard that fits my requirements. Sadly that is pretty difficult. The best thing I found is this.http://www.newegg.com/Product/Product.aspx?Item=N82E16813131389&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-Branding-_-na-_-na&AID=10440554&PID=4897915
The requirements for this board are:
  • ATX form factor. I already bought the case. ATX is the biggest board it supports.
    Won't cause issue with the CPU coolers. The be quiet! DARK ROCK 3 SilentWings CPU Cooler says it will support LGA 1366 so I think it would be cool to have two. Not sure if they will fit though.
    SATA III and raid 0 support. I would like to get the full performance out of the ssds. This seems to be really hard to find on a dual socket 1366 board. All I saw are SATA II.
    If possible 2 pcie slots for 2 video cards. Would like to do some test with my old gx 750.
The Asus board looks pretty good but would like to know if someone knows about something better or I would like to be told I'm stupid to not just get the new CPU, RAM, and motherboard.
Thanks everyone.
lol. There is one on ebay for $350 with the dual E5-2670s included. So I might buy that tonight.
Update:
Ok so it looks like a lot of these boards are SSI EEB form factor. I am not family with that form factor. Will that work with a EATX case? I can return the be quiet case. Still in the box so I need to start looking for another case.
kogo50,
If you're interested in LGA1366, Supermicro has a bewilderingly large number of variants of LGA1366 motherboards. Dual CPU motherboards are typically E-ATX to accommodate not only the two CPU's but often 16 RAM slots. Since the extra CPU adds PCIe lanes, there are usually more PCIe slots as well. There are ATX- dual Xeon boards, but they look very cramped and I would think would require a careful CPU cooler choice that wouldn't collide with the RAM. There is a Supermicro ATX 1366 dual board with dual GPU slots which accomplishes it by having only 6 RAM slots.
However, if you're making a change or motherboard, there are great advantages to LGA 2011. This would mean you can sell the T5500 intact and apply the value to a newer and more versatile technology. There is a Supermicro dual LGA2011 motherboard that is ATX, although it has only a single GPU slot.
Supermicro also make "Superworkstations" for LGA1366, LGA2011, and LGA2011-3. The great feature of these besides the excellent server-grade motherboards is that they include the case, motherboard, massive power supply, and arrive with dual CPU coolers, so you just plug in the CPU's, RAM, GPU, and drives. These typically support two 150W GPU's and the variants have useful features such as hot swap drive bays. This is much simpler than sourcing parts from all over, assembling, wiring, etc. So, everything is new except you can use highly depreciated CPU's. They're supposed to be very quiet as well. This is what I'll be doing for my next system.
With a Supermicro SuperWorkstation SYS-7038A-I Dual LGA2011 900W Mid-Tower Workstation Barebone System (Black) $650- you could add a pair of Xeon E5-2680's, which are 8-core @ 2.7 /3.5GHz and these days about $150-180 each. That's about $1,000 and then add a RAID controller, for example a used LSI MR9260-8i, plus the RAM. GPU, drives, and etc.
If the E5-2670 2.6 /3.3GHz is sufficient, then you can make even shorter work of the project and save a bit by considering a used Dell Precision T7600. Quite a few were sold with E5-2670's. The one in the link for $999 has two E5-2670's, 16GB of RAM, and usefully, a PERC H310 RAID controller- that was a $300 option and those are quite fast. I added an H310 to my T5500 and without other changes the disk score went from 1940 to 2649. There were also a lot of HP z620's with E5-2670. Overall, the Superworkstation being a new basic system and E5-2680's seems a bit more attractive approach.
Performance should be very good. The average CPU score on Passmark for a pair of E5-2680's is 18926 (top score 20974), and for a pair of X5650's, 11735 (top score 17375). The single-threaded performance of an X5650 is 1235 and for an E5-2680, it's 1709.
Cheers,
BambiBoom
Modeling:
1. HP z420 (2015) > Xeon E5-1660 v2 (6-core @ 3.7 / 4.0GHz) > 32GB DDR3 1866 ECC RAM > Quadro K4200 (4GB) > Intel 730 480GB (9SSDSC2BP480G4R5) > Western Digital Black WD1003FZEX 1TB> M-Audio 192 sound card > 600W PSU> > Windows 7 Professional 64-bit > Logitech z2300 speakers > 2X Dell Ultrasharp U2715H (2560 X 1440)>
[ Passmark Rating = 5064 > CPU= 13989 / 2D= 819 / 3D= 4596 / Mem= 2772 / Disk= 4555] [Cinebench R15 > CPU = 1014 OpenGL= 126.59 FPS] 7.8.15
Pending upgrade: HP /LSI 9212-4i PCIe SAS /SATA HBA RAID controller, 2X Seagate Constellation ES.3 1TB (RAID 1)
Rendering:
2. Dell Precision T5500 (2011) (Revised) > 2X Xeon X5680 (6 -core @ 3.33 / 3.6GHz), 48GB DDR3 1333 ECC Reg. > Quadro K2200 (4GB ) > PERC H310 / Samsung 840 250GB / WD RE4 Enterprise 1TB > M-Audio 192 sound card > Logitech z313 > 875W PSU > Windows 7 Professional 64> HP 2711x (27", 1920 X 1080)
[ Passmark system rating = 3844 / CPU = 15047 / 2D= 662 / 3D= 3500 / Mem= 1785 / Disk= 2649] (12.30.15)
BambiBoom,
Thanks for the info. While I like the pre-built workstations I do want to do a custom build on this. I normally go for just a plain black case but I kind of want to do some lighting and have a windowed side panel this time. I've decided to send the case back and get a new larger case. Still looking for that now. Then I'll get a dual LGA2011 motherboard and most likely get Xeon E5-2670s or E5-2680s. I've seen a good bit on ebay. I'm personally not worried about used server parts. They generally are fine. Just have to be careful with the CPU heatsinks. I would really like to use the be quiet heatsinks. Looking at the cases they seem to have a large enough cut out on the motherboard tray to deal with dual sockets.
kogo50,
With this kind of system, a good sized mid tower will work, but if you have the space a full tower is easier to work on.
Here's one that I llke, that can use E-ATX boards, the Thermaltake Urban ($175), The interesting feature are the double doors- one has a window to the motherboard and the other opens to reveal the stack of 8 drives. A great solution to drive access. Very clean-looking and has well-thought out air flow for cooling.
Cheers,
BambiBoom
I should have space for a full tower. Looking around on supermicro's website I found a few boards with 2 - 3 pcie x 16 slots that have dual LGA 2011 sockets. Will have to look around for the best price. On ebay new ones are around $400 - $450.
