Question Would lowering my fan speed cause overheating problems?
ThatSourMelon
Commendable
Apr 21, 2019
363
12
1,715
I have a case that has a button that lowers the case fan speeds, it gets significantly quieter, but I’m a bet worried. I game a lot and, although I would prefer it to be quiet, I’m worried that having the fans at low speeds might shut my system down because of overheating, if the system is getting too how will the fan speeds go up again? Or will they shut the system down if it gets too hot? Should I ever lower the fan speeds?
Zephyl
Commendable
Mar 13, 2017
377
52
1,740
I can't really tell you the answer to this. It may or may not. Use a monitoring software such as RivaTuner to keep track of your temps (especially CPU) while you're in this "quiet mode." If your CPU temperature gets into the 80s under load, you probably shouldn't use it. I wouldn't use it anyway as I prefer to have the best temps possible at all times, but I sacrifice silence for that.
Reactions: Crosslhs82x2
Ralston18
Update your post to include full hardware specs and OS.
The fans should increase speed as temperatures rise unless that function is disabled or otherwise not working. If the CPU gets too hot it should shut down on its' own accord.
Are you able to monitor the fans and temperatures?
Just make minor adjustments as necessary to balance noise and cooling.
