V VVQuick Distinguished Feb 8, 2015 15 0 18,510 Sep 25, 2019 #1 Hi I have a Poweredge R710 with onboard 4port ethernet; It also came with a 4port pcie ethernet card. If I installed this in another pc would I get increased throughput between the 2 ? Thanks
Solution Ralston18 Sep 25, 2019 Not an answer per se - I think more information is needed because multiple factors affect throughput. R710 specs: https://www.dell.com/downloads/global/products/pedge/r710-spec-sheet.pdf The physical connectivity that you have in mind being the following line diagram: PowerEdge R710 [Onboard LAN port] ---Ethernet cable --> [Router] ---Ethernet cable -->[LAN port on 4 port PCIe] Host pc. Edit/correct the line diagram as necessary. Other network devices? Add some details about how the system is currently configured and networked plus what changes (if any) you expect to make.
Ralston18 Titan Moderator Oct 11, 2014 34,816 3,309 146,290 Sep 25, 2019 Solution #2 Not an answer per se - I think more information is needed because multiple factors affect throughput. R710 specs: https://www.dell.com/downloads/global/products/pedge/r710-spec-sheet.pdf The physical connectivity that you have in mind being the following line diagram: PowerEdge R710 [Onboard LAN port] ---Ethernet cable --> [Router] ---Ethernet cable -->[LAN port on 4 port PCIe] Host pc. Edit/correct the line diagram as necessary. Other network devices? Add some details about how the system is currently configured and networked plus what changes (if any) you expect to make. Upvote 0 Downvote Solution
