Would my custom pc parts be compatible with each other?
Roshan0609
I am going to be building a PC. However I am not sure if my parts are compatible with each other. Could someone kindly tell me if the following parts would work together. Thankyou.
Intel i5 4670 core processor
Asus H87 - PRO Motherboard
Kingston 1600 8gb Ram Single Stick
Gigabyte GTX - 660 OC 2gb graphics card
Cooler Master Universal Hyper 212 Evo (CPU Cooler)
MSi dvd drive
TPLink WN822 Network Adapter 300 MB/s
Thermaltake lite power 600W power supply
Aerocool Strike X Advance Black Case
Seagate 1 TB HDD
Sandisk 128GB SSD
If something doesnt work, what component could I swap?
Here :
Much more balance build that is way under budget. Now if you want to spend more, then get a better graphics card FIRST, then move from there.
PCPartPicker part list: http://pcpartpicker.com/p/1PMMw
Price breakdown by merchant: http://pcpartpicker.com/p/1PMMw/by_merchant/
Benchmarks: http://pcpartpicker.com/p/1PMMw/benchmarks/
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor ($194.94 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Motherboard: Gigabyte GA-B85M-D3H Micro ATX LGA1150 Motherboard ($79.99 @ Amazon)
Memory: Corsair Vengeance LP 8GB (2 x 4GB) DDR3-1866 Memory ($64.99 @ Newegg)
Storage: OCZ Vertex 450 Series 128GB 2.5" Solid State Disk ($79.99 @...
My budget is around $1000 - $1200
I want the cheapest price possible. So I dont mind if I have to swap any other components out.
Thankyou.
Where are you purchasing from?
At 1000$ you should be able to get a MUCH more powerful GPU.
I am from Australia and I am buying From a company called msy
Here :
Storage: OCZ Vertex 450 Series 128GB 2.5" Solid State Disk ($79.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Outlet PC)
Video Card: Asus GeForce GTX 760 2GB Video Card ($255.66 @ Newegg)
Wireless Network Adapter: Rosewill RNX-N150PCx 802.11b/g/n PCI Wi-Fi Adapter ($11.99 @ Amazon)
Case: Aerocool StrikeX-Advance ATX Mid Tower Case ($59.99 @ NCIX US)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($49.99 @ NCIX US)
Optical Drive: LG GH24NS95 DVD/CD Writer ($15.00 @ Newegg)
Total: $885.50
(Generated by PCPartPicker 2013-10-17 02:24 EDT-0400)
Thankyou for your help. Just two more questions.
What is the difference between intel 4670 and 4570?
And
Would you be able to tell me a good powersupply from the following companies, as XFX is not available my country.
The companies i can pick from are shaw, aerocool, antec, coolermaster, cosair and thermatake. And tell me howmany the watts i should get
Thankyou.
You can not go wrong with an Antec or Corsair.
I would suggest you get at least a 550W from one of those 2.
The difference is 200MHz betweent he 4570 and 4670, so if the cost difference is larger than a few dollars, then the 4570 is a better option since you can use that money elsewhere.
