Would Static Pressure fans help pull more air through a case that has a door?
TommyRiley
33
I have an NZXT H2 a very old case. With a door that doesn't have any airflow capabilities other than the bottom and around the edges. I was wandering if statci pressure fans could pull more air than the stock fans that came with the case.
I don't think so. Those air vents in the case are meant to be low restriction. Even if static pressure front fans were superior, I think the cooling difference would be negligible. Your best bet for additional CPU cooling is to place a 140mm exhaust fan in the rear roof position, though it would add a bit of noise to the silent optimized case. If the GPU is too hot, add a floor intake fan.
