Would these go together?? pls help
The parts will fit in and work well.
all the AM3+ MoBo available in Flipkart are either ATX or Micro-Atx form factor. If you are ok with Micro-ATX then you can opt for ASUS M5A78L-M/USB3
http://www.flipkart.com/asus-m5a78l-m-usb3-motherboard/p/itmdk2kauzgdtyvy?pid=MBDDK2KAUZGDTYVY&srno=b_3&ref=f0d7d6a9-6a57-49c9-bdad-cd5ee83d541a/
Instead of fx4300(4-core), you can go for fx6300 (6-core) and split the RAM in 2X4GB (=8GB) as it will be faster on a dual channel chipset.
Form factor for 970A-G43 is ATX, so you will need a cabinet that can fit an ATX size motherboard in it.
