Would these parts fit?
Chunkyspudface
7
I have an old case and am going to take out all the aging components and replace them. The case is:
http://www.trustedreviews.com/Advent-PQG9002-PC_Desktop-PC_review
170 x 400 x 355mm (WxDxH)
This is the same as mine, although mine doesn't have the GPU at the bottom.
I'm planning to add an
i5 4570 CPU
MSI H81M motherboard
Arctic Alpine 11 CPU cooler
Zalman 600W power supply
4gb Corsair Vengeance RAM
1TB Seagate storage
GTX 760 (Other choices are GTX 670 or HD 7950)
I know all the parts are compatible with each other, but am unsure of if they'll fit inside properly. The GPU is the main worry as some models are obviously too big...
I have not found any info on the space clearing for the GPU, so I can`t confirm that the GPU will fit well in there.
Is it not possible to get another case for your build? I`m sure you can find something good for cheap.
