Would these parts work together?
this is the best you can get for that budget
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($88.20 @ SuperBiiz)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard ($40.40 @ SuperBiiz)
Memory: Kingston 8GB (2 x 4GB) DDR3-1600 Memory ($34.20 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($40.50 @ SuperBiiz)
Video Card: MSI GeForce GTX 950 2GB Video Card ($139.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($48.60 @...
The PC is going to be used for gaming. Please try to keep the build under around 435. I have a windows and all that stuff. Just need the actual pc it self. Including the dvd drive.
I can help you make a PC, but you have to answer these questions:
Do you need a mouse / keyboard?
Do you need an OS?
Do you need a monitor?
Do you want any other peripherals? (such as speakers, headsets, etc.)
Do you plan on using a wireless or a wired internet connection?
That, and I need a budget.
I need none of that stuff you just listed.
I already have a wireless adapter so I'm good there also. Just need the PC itself.
Budget around $400-$425
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($48.60 @ SuperBiiz)
Total: $421.88
Generated by PCPartPicker 2015-11-02 07:47 EST-0500
it will not max out current gen games, but it's a big improvement compared to your build
