Would this be an appropriate Positive Air Flow Solution?
Bscull12
102
So I have been thinking, most cases want your air to go from the bottom front to top back, but usually that creates negative pressure, and I dont want that. Would this be an acceptable solution? What would I need to change if I do need to change something? The case I will be using is the Corsair 570X.
https://imgur.com/a/6PVateC
Thanks!
Positive/negative air pressure is overrated to be honest. It really does not make a big difference on temps or dust. Airflow, not the type of flow matter much more.
Theres a reason cases are laid out in the way they are, in your config the rear fan blowing in would disrupt airflow quite a bit, creating a big swirling mess in the case instead of a uniform flow.
