Would this choice of parts work?
madattack__
Excuse my very big noobieness, but this is my first pc build so I'm pretty nervous that I'll mess something up so I wanted to ask some veteran pc builders first, also if you have any other suggestion for parts don't be afraid to edit the list.
here's the list: http://pcpartpicker.com/p/HLfQmG
Those components will all work well together. You did OK.
I would suggest you either get 2x4GB or 2x8GB of memory, because with only one stick you loose dual channel memory mode for about a 10% performance drag. Be sure to buy the memory in MATCHED pairs for the most problem-free results.
While the GTX 750 Ti is a nice low end card, for a very few dollars more, you can get a GTX 960 for much better gaming performance.
