Would this power supply be enough for SLI?
nirrtix
348
In this system would this power supply be enough for sli? I intend to overclock to 4.5 as well... I am curious becuase someone said he could not SLI with 2 660's HE did however have liquid cooling which may use a ton of power.
- (Bought) Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics
- ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- DDR 3 16 GB 1866 mhz (Patriot Brand)
- Black Enermax Hoplite SECC ATX Mid Tower Comput...er Case ECA3220, w/ Side Window and 12cm Blue/Red Combo-LED .
- CORSAIR CX Series CX750 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
- COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible with Intel 1155
- Seagate 1TB Serial ATA/300 Hard Drive
- Black LG UH12LS29 Internal SATA 12x LightScribe Blu-ray Optical Drive, w/ 3D Playback and M-DISC Support, 16x DVD+R/-R, 4MB Cache. OEM
- (Bought) GIGABYTE GV-N670OC-2GD GeForce GTX 670 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
- (BOUGHT) Corsair Force Series GS 2.5in 360GB SATA III 6Gb/s Internal Solid State Drive (SSD), Model: CSSD-F360GBGS-BK. ds-dh
I'm not an expert, but by the looks of it i would say it's plenty for x2 660's.
Try one of those wattage calculators, and see what it spits out, just so you have a number to go for. Not sure if they're 100% precise though.
I tried in one of the calculators for two 670s... probability was the guy was an idiot or got a faulty supply unit. I got the TX enthusiast 750 though becuase the CX I mentioned did not have as good of rails.
