Would three 60hz montiors work well with a single 120hz monitor?
Seemefly
Hello, I've got a couple questions regarding higher refresh rate monitors.
I have three AOC 21.5" IPS LED HD Monitors 60hz displays running on a triple monitor set up. I was thinking of getting a 120hz or 144hz gaming monitor to put in the center and do a 1 over 3 monitor set up.
But I was wondering if it would be an 'eyesore'? Since the higher hz monitor would be running at a faster rate then the other three 60hz montiors. I would think they'll lag behind correct? For example like if I was to do a Nvidia Surround set up in supported multi monitor game.
The reason I wanted to get a single 120/144hz monitor, was because I play a lot of CS:GO, some people claim that they benefited from the higher refresh rate. Although I'm not sure if it's worth shelling out the money for one. Monitors with G-Sync are even much more.
Got any advice?
Computer's Specs:
CPU: Intel Core i7-4770K Haswell 3.5GHz LGA 1150 84W (Overclocked to 4.3 GHz)
Motherboard: ASUS MAXIMUS VI HERO LGA 1150 Intel Z87 USB 3.0 ATX Intel Motherboard
RAM: G.SKILL Ripjaws Series DDR3 8GB (2 x 4GB)
GPU: GIGABYTE GV-N970G1 GAMING-4GD GeForce GTX 970 4GB 256-Bit GDDR5
Sound: ROG SupremeFX Audio 8-Channel High Definition Audio (Realtek HD Audio)
Storage: SAMSUNG 850 EVO-Series SSD 1 TB, 2x Seagate Barracuda 7200.12 HDD 1 TB
ODD: Pioneer Blu-ray Burner SATA BDR-209DBK
PSU: EVGA SuperNOVA 1000 P2 80 PLUS PLATINUM Certified 1000W PSU
Case: NZXT Phantom PHAN-001BK Black Steel ATX Full Tower Computer Case
CPU Cooling: Cooler Master Hyper 212 EVO
Fans: 1x NZXT 140mm Blue Front LED Fan, 2x NZXT 120mm Blue LED Side Fans, 1x NZXT 120mm Blue LED Rear Fan, 2x NZXT 200MM Blue LED Top Fans, NZXT Sentry 3 Fan Controller
OS: Windows 7 64-bit Home
Seemefly
I would think they'd look un-synchronized, since the monitor with the highest hz would be running faster then the other lower hz montiors? Just wanted to make sure before I decided to actually buy one.
