Would water cooling be worthwhile in an ivy bridge build?
johnkerr06
Commendable
Nov 15, 2016
4
So my build i slisted below, I have just added a ASUS Strix GTX1070 08G to my system, I have my clock st 4.5 GHz curently. I'm generally hitting around 74c at max game load. Would it be worthwhile going watercooling to push the clock higher? I eventually want to update to a skylake build when the prices drop off, which could be 6 months to a year.
-GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-Intel Core i7-3770K Ivy Bridge Quad-Core 3.5GHz (3.9GHz Turbo) LGA 1155 77W
-CORSAIR Enthusiast Series TX650 650W ATX12V/EPS12V 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
-G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
-SAMSUNG 840 EVO 2.5" 500GB SATA III TLC Internal Solid State Drive (SSD)
You could lower your temps with a good AIO if thats what your after. However, unless you really want to push the voltage, its unlikely you can go much higher in clockspeed even under water. Ivy Bridge doesn't go much higher than 4.5Ghz for most.
