Last week my wife said she was hearing a noise from her computer and it sounded like something caught in a fan. So, I powered down and pulled the GPU, because there are cables beneath which could interfere with the GPU fan. I tied the cables down and reinstalled the GPU. Then, received a "CPU error" on the mobo.
So, I removed the CPU. But, when I did, it was stuck to the cooler and pulled out of the socket without unlocking. Then, I found a couple of bent pins on the CPU and went out for a replacement. Reassembled and "CPU" error was still popping.
At this point I thought I tweeked the mobo and ordered a new one. The new CPU and Motherboard fixed all of the issues. So, now onto the real reason for my post:
When reassembling the first time, I plugged an errant cable (looked like part of the case fan daisy-chain) into a System Fan port. I didn't force the connection and it was definitely not the correct thing to do. However, before I powered everything back on, I did unplug this cable. So, could a random cable, plugged into a System Fan port cause a CPU error and the system not to boot?
Thank you for any advice.
