Hello,
I have AOC F22 monitor (not AOC V22) as it's clearly visible on the next picture:
Also the NVIDIA control panel shows AOC F22 too:
Problem:
My screen resolution window shows I have AOC V22, which is wrong:
I am forced to play on 16:10 ratio (1680 x 1050) instead of 16:9 (HD 1920 x 1080 which is supported by AOC F22). If I try to change to 1920:1080, the screen doesn't fit (it goes beyond the left and right edge) and is too narrow, meaning: circles are not circular but egg-shaped. Maybe I should switch from VGA to DVI cable if that helps?
Additional info:
Problem:
Additional info:
System specs: https://i.imgur.com/wux9NzD.png
System specs 2: https://i.imgur.com/HzjhiXM.png
AOC F22 specs: https://www.cnet.com/products/aoc-f22-lcd-monitor-21-5-series/specs/
AOC V22 specs: https://www.cnet.com/products/aoc-v22-verfino/specs/
