Question Wrong PSU for RX 570
Iniaskle
Commendable
Mar 5, 2019
292
25
1,740
Hi there, I made a very stupid mistake,it's my brother's birthday so i ordered him an rx 570 that needs a 1 x 6 pin, guess what his psu doesn't have that. what is a recommended psu that is NOT expensive with not expensive i mean under 55 euro's.
This is his psu right now, it's a terrible one btw: https://www.amazon.de/LC-Power-LC420H-12-Netzteil-V1-3/dp/B0012BBLPE
Will this one work? http://www.coolermaster.com/powersupply/b-series/b400ver2/
It's one 400w but he doesn't do overclocking.
His specs:
CPU: Ryzen 3 2200G
GPU: https://www.asrock.com/Graphics-Card/AMD/Phantom Gaming M1 Radeon RX570 4G/ but can't use it yet because of wrong PSU
Motherboard: https://www.msi.com/Motherboard/a320m-pro-vh-plus.html
PSU: https://www.amazon.de/LC-Power-LC420H-12-Netzteil-V1-3/dp/B0012BBLPE
RAM: 2 sticks DDR4 4GB
While AMD does recommend a 450 watt PSU, they are making that recommendation without knowing what kind of other hardware the card will be paired with. The 2200G isn't a particularly power-hungry CPU, so I suspect a semi-decent 400 watt might be okay. If it doesn't cost much more to go with a 500 watt model, it's probably worth doing so though.
As for the connections, that 400 watt Cooler Master does appear to have a PCIe 6+2pin cable. Most 500 watt PSUs should typically include two of them. Again, while it might work, paying a little bit more for a 500 watt unit like the one in the previous post might be a safer bet, and better suited for potential future upgrades.
Again, it may work but maybe not for long. If it does fail, it could kill everything in your system, or even worse. It's not worth risking $500 of hardware to avoid spending $50 on a quality PSU.
Also what do you mean with not for a long time, after i get that GPU i can get a new psu the next day.
Which one would be best? http://www.coolermaster.com/powersupply/80-plus/mwe-bronze-550/ or https://eu.evga.com/products/product.aspx?pn=100-W1-0500-K2
In my country the Seasonic ones really cost way more then in the US so that's why i don't pick those.
Is it better to pick a gold one or would bronze be fine?
