Archived from groups: microsoft.public.win98.gen_discussion (
More info?)
Did you uninstall and reinstall all the network protocols currently installed in the
Network control panel?
Did you uninstall and reinstall Dial-Up Networking, from Add\Remove Programs>
Windows Setup tab?
Glen Ventura, MS MVP Shell/User, A+
http://dts-l.org/goodpost.htm
http://www.microsoft.com/communities/conduct/default.mspx
"Rick Kaser" <RickKaser@discussions.microsoft.com> wrote in message
news:5D66BAF2-A3C6-47E6-A9D2-DE0E46B1644F@microsoft.com...
> tried both lspfix and removed/reinstalled all netwrok drivers. Still get the
> same error msg. Went to McAfee and they ran me through a virus scan from the
> DOS environment -- - still no joy. Any other ideas???? s/Rick
> "glee" wrote:
> > I suggest you first try LSPFix:
http://www.spychecker.com/program/lspfix.html
http://www.cexx.org/lspfix.htm
> > Here is a reply by MVP Jeff Richards, to the same problem from a user a year
ago:
> > "A program is trying to find out how to perform a particular network
> > operation, and the routine it is using for the operation has failed to load
> > or initialize. You could try removing and reinstalling each of your network
> > protocols. You should also check exactly which program is trying to do this,
> > as worms or viruses sometimes try to use network functions to propagate or
> > to phone home."
> > news:0E67CA8F-9427-40DB-AAB1-B40AA9A15253@microsoft.com...
> > > I am having severe problems on an old Dell running W98SE. After boot up into
> > > windows - - I get an error msg for any application that I try to start. The
> > > error message reads as follows:
> > > WSCGetProviderPath failed, returning WSAEProviderFailedInit
> > > I have found nothing to help me resolve this issue. Any ideas??? s/Rick
