X-Fi Extreme Gamer, got the card need a little help
AreeSoothsayer
98
Well I popped it in and installed the drivers, per advise from my last post, but it doesn't show the right setup of ports in the back. It only shows 3 and while plugging in my speakers into the first works fine when I try the others for my headphones to switch to I can't get anything out of it.
My tower is an oldy and doesn't carry build in headphone jack to plug the sound card into. I've gone through all the software that came with the drivers to no avail.
AreeSoothsayer
98
Already disabled the onboard before installing the card. Removed the old drivers by uninstalling the sound. Checked the sound options, that is the part that is showing the incorrect plugin arrangement.
Add: I examined it a bit closer. LR, RR RL, Base. Switched 4.0 and got the rear sounds through my headphones. Is there a way to make front and rear send out the same thing? Continueing to figure it out on my own.
