Question X.M.P issue on B450M PRO-M2 V2
Dec 2, 2021
.if i turn on xmp then pc starts then goes to green screen(profile 1 or profile 2 both are the same)
i am having issues on
B450M PRO-M2 V2 - MSI
motherboard..if i turn on xmp then pc starts then goes to green screen(profile 1 or profile 2 both are the same)..and yes i am using the latest bios. can u guys help me? pc runs normal when pc runs on default. main problem is xmp doesnt work. Noted i first bought one stick 8 gb then after 5-6 month i bought another..
Processor AMD Ryzen 5 3400G with Radeon Vega Graphics
Installed RAM 16.0 GB (13.9 GB usable) Ripjaws V (8x2) 3200 bus
System type 64-bit operating system, x64-based processor
Edition Windows 10 Pro
Version 21H1
mobo :
Lutfij
BIOS version for your motherboard? Try manually inputting the frequency, timings and voltage as shown on the ram kit's sticker into BIOS. Make and model of your PSU? How are you cooling that APU? Parse an image to both sticks of ram's stickered side.
Dec 2, 2021
MSI B450M PRO-M2 V2
7B84v4D5(Beta version)
I was using 7B84v4A version but same problem XMP dont turn on then i update bios
PSU-Corsair CV Series CV450 450 Watt 80 Plus Bronze Certified Power Supply
Ram- 1) G.Skill Ripjaws V 8GB DDR4 3200MHz Black Heatsink Desktop RAM
CAS Latency16-18-18-38
2) G.Skill Ripjaws V 8GB DDR4 3200MHz Black Heatsink Desktop RAM
Tested Latency- 16-18-18-38-2N
its a double ram slot mobo.... And i am using the stock Amd cooler
