Ok I just put together this system last night. Everything boots up and seems to run fine. I installed oblivion (excited to see it with all the stuff turned on) and it was great for about 20 seconds then a bunch of weird artifacts started to appear. If I exited right away they stop and windows looks fine. If I keep going my screen goes black and the monitor gets no signal until I restart. I'll be updating the drivers tonight, but something tells me that's not going to fix my problem. I know I can try more cooling on the card but it just doesn't seem to be that hot. Maybe the power supply isn't enough? I've included the specs for it too. Maybe someone can tell me if it's ok or has some other ideas I can try.
Thanks.
SAPPHIRE 100154L Radeon X1800XT 256MB GDDR3 PCI Express x16
AOpen 16X DVD±R DVD Burner Beige E-IDE/ATAPI Model DUW1616L
ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard
Rosewill RP550-2 ATX 2.01 550W Power Supply
Microsoft Windows XP Home With SP2
Patriot Signature 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory
Western Digital Caviar SE WD1200JBRTL 120GB 7200 RPM IDE Ultra ATA100 Hard Drive
COOLER MASTER Centurion 531 RC-531-SSN1 Silver Aluminum bezel, SECC chassis ATX Mid Tower Computer Case
Power supply specs
Type ATX 2.01
Maximum Power 550W
Fans 120mm Blue LED Silent Fan
PFC No
Main Connector 20+4-Pin
Dual +12V Yes
Hold-up Time 16ms min.
Efficiency > 70%
Over Voltage Protection YES
Overload Protection YES
Input Voltage 100 - 240V
Input Frequency Range 47 - 63Hz
Input Current 10ARMS max. for 115 VAC 5.5ARMS max. for 230 VAC
Output +3.3V@30A, +5V@50A, +12V1@18A, +12V2@18A, -12V@1A, +5VSB@2.5A
MTBF 100k hours at max. load, normal line and 25°C
Approvals CSA, CB, TUV, FCC, UL
Features
Features Built-in inrush current, over temperature, over current, and over voltage protection circuits, Silent 120mm Ball-bearing Fan with Blue LED, (20+4) pins Main Power x1, 12V(P4) x1, Peripheral Power x 8, Floppy x 2, Serial ATA x 2, PCI-E (6 Pins) x1, server use 8 pins CPU connectors (12V) x 1
Thanks.
Power supply specs
Type ATX 2.01
Maximum Power 550W
PFC No
Dual +12V Yes
Efficiency > 70%
Features
