Question X570 Aorus Pro memory problem
AdrianVaughan
146
hi all , i have just got a new board the x570 aours pro , everything is working fine apart from trying to get my memory to 3200
am on the list of compatible memory modulus
3200 CORSAIR 8GB CMK16GX4M2B3200C16 DS 16-18-18-36 1.35v 2133 only difference is mine has a R at the end , which i take it stands for red as i have red metal heatseak on it , now when i try to enable the xmp on it , its just stays in the boot loop the leds on my board cycle but stop on dram , then , then it clears the cmos it self and reverts back to 2100 again , can anyone help me on this please thanks.
Oct 2, 2019
Hi Adrian - i have exactly the same issue with G-Skill Trident. Every word you said its exactly the case with my mobo and ram.
On the minute I am only runnning @2100mhz, because every time i turn on XMP, system won't boot up, and I had to clear CMOS, waiting for new Bios, currently using F6b. If i will find solution - i will come back to You.
My ram is
G.Skill Trident Z, DDR4, 64 GB,3200MHz, CL15 (F4-3200C15Q-64GTZ)
