Question x570 aorus Xtreme ethernet question
thanulee
218
Hi,
I am thinking to buy this mobo for the 10gbit ethernet port. I am planing to use 2 x 3090 which run super hot in general.
Do you think I will have disconnect issues with ethernet cause of temps? I have some 5g dongles and they also run very hot and disconnect all the time.
Its a very expensive mobo and the only reason i wanna upgrade is for the ethernet. Any bugs, gotchas I should be aware of?
Thanks
kanewolf
Hi,
Thanks
I doubt anybody can answer your question because, nobody will have the configuration you are proposing.
thanulee
218
Hehe maybe not that specific.
At least if anyone has the mobo without the gpus?
I ve been reading random posts online about 10gbit ports in various mobos disconnecting and I wanted to ask about that specific model.
