Question X570, B550 Aorus Pro, B550 Vision D
May 7, 2021
9
Hi Sirs,
Anybody here using GIGABYTE X570 Aorus Pro, GIGABYTE B550 Vision D or GIGABYTE B550 Aorus Pro with Ryzen 5 3600 proc? I just want to ask if AMD-V can be seen using cpu-z or hwinfo after enabling svm in bios. Thank you in advance!
maikutech
Hi Sirs,
You need to check it yourself to be sure of that, cpu-z should display it under the "instructions" in the cpu tab.
May 7, 2021
9
My mobo is B450 Aorus Elite but it doesn't show in cpu-z. If any of the above mentioned mobo will show the instruction in cpu-z, I'm going to buy it. I am suspecting my mobo despite of svm being enabled in bios, it still does not show it
