Should i get a gigabyte aorus elite mobo x570 at 202€ or a b450 msi tomahawk max at 124€ and save some money is the price difference worth it?For the ryzen 3700x.
3800x isnt worth it so much 3700x will be perfect for me i am just not sure if the x570 is worth the extra moneyI'd say go up to the x570. In reality you are probably getting a better overclocking headroom and future access to pcie4 for whatever that's worth. The b450 tomahawk is a solid board, fair decent vrms so you aren't missing out on much if you choose that option. I'd usually recommend going up a tier with the cpu rather than spend a load on a higher tier mb but my understanding is the 3800x isn't worth the extra money.
