Question X570 Pro4M Mobo w/ Intel 2230 BT module doesn't work
Dec 3, 2019
I recently got an Intel 2230 WiFi/BT module and installed it on the my mobo. Windows found it and the drivers are current from Intel, but it will not find/pair with any devices. The WiFi also shows no networks found. Is there something special I need to do to get this thing working?
Specification
https://www.asrock.com/mb/AMD/X570M Pro4/#Specification
Rear Panel I/O
- 3 x Antenna Ports (on I/O Panel Shield)
Instructions:
Step 1 Prepare the SMA Wi-Fi Antenna Cables and WiFi 2.4/5 GHz Antenna that comes with the package. (These hardware items may not be included with the ASRock X570M PRO4)
Step 2 Attach the SMA Wi-Fi Antenna Cables to the WiFi Module.
Step 3 Insert the RP-SMA Wi-Fi Antenna Con-nectors to the antenna ports on the I/O shield.
(see page 11)
http://asrock.pc.cdn.bitgravity.com/Manual/X570 Phantom Gaming 4 WiFi ax.pdf
Specification
Rear Panel I/O
Instructions:
(see page 11)
The connectors on the AX200 module are for WiFi only and would have no effect on the Bluetooth Radio, which also isn't working as stated in my original post. So antenna are not the issue.
