Question X570
Jul 20, 2021
21
Guys, i need your help. I am planning to buy a motherboad for my Ryzen 7 3700x, i am a bit confuse whether i should buy MSI MAG X570 tomahawk wifi or Gigabyte X570 Aorus pro. Although Gigabyte has been one of my favourite brand. Should i switch it to MSI motherboard. I don't know much about their performance. So, please help, anyone.
boju
Ambassador
I did a search gigabyte x570 aorus pro vs msi x570 tomahawk. Theres a few different discussions on Reddit between these boards. Can't go wrong with either. Gigabyte seems to have a better audio chip if onboard audio is something youd look into.
Jul 20, 2021
21
Thank you, my main concern is performance and durability. I know that most gigabyte motherboard durability is very good.
boju
Ambassador
Performance and durability has been described as equal between the two that i can see discussed. There are like 4 or 5 discussion threads between those two. Both are great boards. Differences being wifi or audio. Id go for Gigabyte for the better audio chip.
Jul 20, 2021
21
Thank you. I think won't be needing wifi as i connect internet through LAN port. Maybe i also will choose gigabyte.
