Just attempted to replace stock CPU cooler that was running a little hot. Disassembled down to CPU core, but did not unseat it, just cleaned, re-thermal pasted, and connected everything as it was.
PC will not post. I have a CMOS Clear light on, the PSU tests OK in another system, and right when I plug in the power, I get a quick flash from the RAM Voltage LED's. Both green and yellow flash for a millisecond, then turn off.
When lit-up power button is pressed, nothing happens. No fans spin, no voltage/temp LED's light up.
Vid Card- Gigabyte GTX 460
Corsair 650 PSU
3 Stick of 4GB G-Skill Ram.
I have attemped to boot with each ram stick individually, with a different HDD, and with no Vid card installed.
UPDATE: Bought a mobo speaker, connected just the 24 pin power, 8 pin cpu power, and cpu/cpu fan, I get no "beeps" at all.
Also, tested the PSU and it is putting out the proper voltages.
Corsair 650 PSU
