X79 mb/i7-3930k possible RAM incompatibility,HELP!
letsrollusafa11
8
Here is my basic build
-i7-3930k
-Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
-GIGABYTE GA-X79-UD3 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-EVGA 04G-P4-2673-KR GeForce GTX 670 Superclocked+ w/Backplate 4GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support ...
-G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
I'm pretty worried because I ran the ram through a compatibility checker and its saying it isn't supported, yet the board manual on GIGABYTE says its supports: Support for DDR3 2400/2133/1866/1600/1333/1066 MHz memory modules
Am I out of luck on this, or should it be fine? I appreciate the help! 🙂
V/R
Chris
Looks like it fits.
