R rileyreidd15 Prominent Jun 26, 2017 1 0 510 Jun 26, 2017 #1 I was told by a friend that i could plug my wired xbox 360 controller into my laptop to play skyrim. Yet, everytime i plug it in the controller just starts flashing green. Ive looked everywhere to try and fix it. Someone please help 🙁
Solution K K kaptainkuftic Jun 26, 2017 Try a different USB port if you haven't yet. Also, go to device manager, plug in the controller, and see if it shows up. You may need to install drivers. Does the controller work on other computers?
K kaptainkuftic Honorable Jul 26, 2016 1,430 1 11,965 Jun 26, 2017 Solution #2 Try a different USB port if you haven't yet. Also, go to device manager, plug in the controller, and see if it shows up. You may need to install drivers. Does the controller work on other computers? Upvote 0 Downvote Solution
S SoccerKid15 Prominent Jun 23, 2017 29 0 540 Jun 26, 2017 #3 kaptainkuftic : Try a different USB port if you haven't yet. Also, go to device manager, plug in the controller, and see if it shows up. You may need to install drivers. Does the controller work on other computers? Yes your right and one of those will fix his/ her problem with the controller not connecting. Upvote 0 Downvote
