Hi there!
I'm having trouble connecting my 360 to the wireless router to gain Internet access.
I use my phone's Wi-Fi to gain internet access with NO issues. My current setup: NetGear Wireless router is connected to my D-Link wired router, and I can access the internet no problem. (10 MBPS down, 5MBPS up)
When I try to connect the 360 to the Netgear Wireless router, it connects to the Network, but Internet test it reads "DNS error - The router or modem may mot be automatically providing DNS settings. Try a manual DNS setting instead."
(Next suggestion) "DNS Error - If you have a PC that can successfully browse the web, check it's network properties to find the DNS address it uses..."
Now, I have XBMC running on my computer, and the 360 can access the network so it shows up under Video Apps so I can see a file list to stream movies. When I try to run a movie, it says I must download an update - so I can't watch the movies at all.
I just need help with the config to set it up so I can access the Network AND Internet.
Again, Netgear wireless router (which 360 connects to) connected to D-Link wired router.
Please help! I'll answer any questions if you think you can help!
