Xbox one controller AA batteries vs play and charge kit for PC
orca-4444
259
I have a few questions:
1. How much more expensive would using batteries instead of the play and charge kit be, factoring in the cost of recharging the controller through a USB port?
2. How long does the play and charge kit battery last?
3. Can I charge an xbox one controller and play with it at the same time?
4. If the answer to number 3 is yes, Will using a computer usb port mean slow charging?
5.Is everything I need to hook up the controller included in the box?
Thanks
It's most likely cheaper to use non-rechargeable batteries instead of using rechargeable or the play charge kit.
Only the play and charge kit can be charged and used at the same time.
if you want to use it wirelessly, you need the xbox one wireless adapter for pc to connect the controller.
If you want to use it wired, you do not need any batteries in the controller. The usb port should provide enough power for the controller to be used.
You do not get a usb cable with your controller. You only get the controller and two AA batteries. You only need a micro usb to usb cable.
