Question Xbox One problem
WhatLuck150
Commendable
Mar 19, 2022
37
I have a original Xbox one, and decided to upgrade the standard 500gb hdd for a 2tb sshd. Well I go into it and swap the hdd and followed the correct steps in setting up the drive and getting the OS loaded back onto it and put it back together and all, then it stops working as it should, boot loops, gives problems installing the OSU. The issue seems to be caused by the metal plate in-between the internal hardware and the plastic shell. Remove that and all the problems are no longer a thing. Any possible idea?
No I can't go back to the old hdd, as I did most of this a while ago and misplaced it
