Xbox One Wireless Adapter, Headset issues
Newerabs
18
I finally picked up the Xbox Wireless Adapter for my PC. So far it's been working great, there is one issue I'm having though.
When I plug in my Turtle Beach Headset (using the Turtle Beach Adapter) I get some static sounding noises coming through the headset. It doesn't happen when I'm using a wired USB cable into my Xbox One controller only when I'm using my Xbox One controller wireless. It's obviously some sort of interference with the Xbox One wireless adapter, I'm just not sure how to fix it.
Has anyone else had this issue? Any fix? Any ideas?
So, it ended up that I had to update the controller via the Xbox Accessories app on my PC. I plugged in my controller through USB cable and then it updated. After that it works flawlessly.
