Question Xeon W-2123 won't turbo boost, stays max @3.7ghz
soewhaty
120
As topic suggests ... anyone ever had that and how to force it to go to TurboBoost 2.0 clock speeds of 3.9ghz? So far no matter what I try I cannot get a stress pattern to make it go beyond 3.7ghz. I tried IntelBurnTest and Prime95 ... nothing.
I can also see in CPU-Z that it is under wattage. Intel ARK suggests 120 watts whereas CPU-Z says 114 watts.
https://ark.intel.com/content/www/u...on-w-2123-processor-8-25m-cache-3-60-ghz.html
I've checked temps and it's all good, nothing too high. Cooling is some stock fan with whatever thermal paste HP or Chinese put there. Haven't touched it. It's a work workstation PC.
3.9 GHz should only be seen in short, single threaded workloads...(You certainly will not see the highest clock speeds in well multithreaded loads)
Looking at HWMonitor to observe all-core/max/min clock speeds, run CPU-Z/Bench/Bench CPU which will both run single and multithreaded benchmarks.
I am not sure I agree. I am monitoring the clock speeds of all my cores with Rainmeter and a plug-in that measures each core individually based off of HWiNfo. Literally at no load whatsoever do I ever get 3.9.
At home I have an OC'ed i7-6800k and it goes without a prob to 4.2ghz which is the max I set it at.
TurboBoost 2.0 for the xeon w2123 says 3.9ghz so I would very much expect at least once to see 3.9ghz yet I can never get up so high. I just tried a stress test with Prime95 and IntelBurnTest and set they at 1 thread per time (I wish I could set them at 1 core) yet this again did not go up to 3.9ghz.
So the admins or mods decided to delete my last post where I said it was a not such a good cpu that I have ... how that is profanity I don't know ... In that same post I also explained that I tested isolating loads per core and thread and it still never went beyond 3.7ghz ... so 3.9 will remain a dream on this CPU ... unless anyone would come up with input but I certainly disagree with @mdd1963 cos I can promise you that turbo boost speed is, can and will be reached on max loads. From then on it's a matter of sustaining this frequency ... so if your cooling is poor the cpu will throttle and if cooling is good it won't and it will just sustain those frequencies.
