Hi there, i bought Xeon X3440 several months ago, but decided to not OC it until i buy more RAM and i haven't done OCing before.
Cooling - DeepCool Gammax 300
What i tried so far:
- Disable Intel SpeedStep
- DRAM Voltage - 1,65 V
- Load-Line Calibration - Enabled
- CPU Multiplier: 0.9
- RAM slowed down from DDR3 - 1333 MHz to 800 MHz (It is slowed down to 1333 MHz by default because of the CPU, it's a 1600 MHz RAM in dual channel)
- QPI Frequency slowed down to 4270 MHz.
- Fixed CPU Voltage - 1.10000
- DRAM Timings - 11-12-12-31 (Not sure about these)
- BCLK from 133 to 200, then stress tested it all with AIDA64 for 10-15 minutes, everything was okay, then i decided to set BCLK to 205, stress-tested it for 15 minutes, then set BCLK to 210 - and that's when my system goes unstable showing me BSoD during stress-test.
