Xfinity router port forwarding problem
onslaught1552
24
As the title suggests, I've done everything that I needed to (or at least as much as i know of) to open ports on my xfinity dpc3941t router. It's also asking for ipv6 which is fairly strange. This router lets you put it in and out of bridge mode, so i tried that but that did not work either. I tried to use my other linksys router with it but i wasnt getting any internet. Here is a picture of what my setup currently is:
https://gyazo.com/2c1710aaf2f97da411b169229ef2def2
Any help would be greatly appreciated. Thanks.
You mentioned bridge mode, which would only be used if another router was located between the Xfinity and your computer. Is this the case or is your computer connected directly to the Xfinity? If not, describe exactly the network configuration.
Have you assigned your PC a static IP address outside of the DHCP range of the Xfinity router?
That message seems to indicate a problem with how the information is entered into the port forward settings.
My initial guess would be the IP addresses. Enter only the IPv4 address, and leave the IPv6 address blank.
Be sure that the actual address of your server is 10.0.0.131.
Ok, so as of right now i have reset the router to default settings, as nothing was working anyways. I also tried leaving ipv6 blank and that did not work.
EDIT: I should also mention that when i put the xfinity router in bridge mode, i was still able to log into it and everything, almost as if it did nothing...
