I have a XFX 4870 1gb on the way. Should be here tomorrow. I picked it up for $142 shipped brand new, is this a good deal? Here is a link to the card (not where i bought it from):
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150436&cm_re=xfx_4870-_-14-150-436-_-Product
After I ordered, I realized this is the revised card with the "poorly" designed heatsink (or so they say) that dumps hot air into the case. I was thinking of taking off the plastic shroud and installing larger 120mm fan (or 2) using zip ties. Has anyone does this before? Would this void the lifetime warranty?
