xfx 650i pins not labeled!!!! help plz
wag2639
9
Hi, I just built my computer and it mostly works.
C2D E4300 x/ stock HSF
Ballistix 2x1GB PC2-6400
320GB Segate
Xfx 8600 GT
Xfx 650i mobo
Cooler Max Elite 330 case
Antec TruepowerTrio 550W
3xRosewill RFA120L-W WHITE 120mm
There are just like 2 things bugging me:
I can't find instructions or any marking for how to attach the front panel audio cables to the board. There are 2 ports, standard mic and speaker plugs but there are 7 wires that are split up. I know the area on the board that it suppose to go to but there are 9 pins there.
Also, there are like 5 or something like that plugs for fans. I plugged in the cpu one correctly and one from the power supply to where it said system. For the 3 Rosewill fans, I'm connecting them directly to the power supply. The thing is that SpeedFan shows my system at -65C and while that would be awesome, I highly doubt that to be close. The cpu is at 28C mostly idle.
Thanks.
For the speedfan problem I suggest you check the settings of the program. You have to chose a different sensor I guess. The CPU temp sounds fine to me.
It's like that at least one of the 2 extra ones is a ground, which you don't need. If it were me, I'd just connect them and see what happens if you know where they go
