I just got a XFX nForce 680i LT, Pentium Duo 2.2, 2Gb (2x1024) of 800Mhz dual channel DDR2, the power supply is a Xion 500W with 4-pin CPU power cord. After connecting all cards, memories, HD and so on, I switch it on. The mobo lights up, the fans are running, the HD is alive, but there is no video, no beeps, no post whatsoever.
I am trying to understand if there is a problem with the CPU power supply. The mobo has a 8-pin plug for the power, but the manual states that a 4-pin cable can be used, and it tells you where to plug it. The problem is, the 4-pin doesn't fit there. It fits in the adjacent 4 pins, but not in the 4 indicated on the manual. And even if it fits in the other four, the position of the 12V - GND cables is reversed.
Any help or suggestion would be greatly appreciated...
thank you
thank you
